Cabinet Recycling
  • Cabinet Recycling
    Well one thing off my honey do or else list. We had/have a T-V cabinet that was too big or should I say tall for our use anymore. Instead of buying a new T-V cabinet or pedestal, I choose to shorten the one we have. I figured if I mess it up no big deal because I would still have to buy another one anyway if I did'nt try.
    This is what the cabinet looked like before I gave it a flat top..
    This is what I ended up with. It worked out great but, most importantly my wife is satisfied with the out come....
    Re: Cabinet Recycling
    Excellent. Modifying for a new purpose is great when done well.
      Beautiful work !@ Lil plasma, 3/32 6010 root , 7018 cover ?
        Re: Cabinet Recycling A LIL WELD HELP
        Both Praxair n air gas don't carry Ni rod any more at My LWS . What's the best on line suppliers
        Have You used crown alloys .035 premium nickel iron Maganese for cast iron Mig ? Thanks Tool
          That there, my friend, is what determines most home projects successes.
          Ron
            Tool, did you by chance post this to the wrong thread?
              Tool,
              If I need Ni rod I buy local. Have not bought on line so, I can't tell you of a good on line store.
              Never used nickel as a wire just SMAW process.. I am going to try 309 stainless wire with 98/02 shielding for cast, people has had great results. It has to be peined after welding... Use on the cold side. V-grove and fill up in shallow passes, pein between beads.
                Yep-per, after cutting very little dross to clean up. Since it was not going to be under stress I used 7014 1/8" for root and cover...
                  Let's head to the Oil sands in Alberta Or Oklahoma. 300 K a year! I got long Johns _60
                    I am a Florida cracker and anything under 75 degrees I freeze. But, I am sure there is a waiting list from guys/gals seeking thier fortune..
