Ridgid Planner "Line in wood"?
  • Ridgid Planner "Line in wood"?
    I have the Ridgid planner, ever since I have had the saw whenever I send the wood in near the lifting side I get a line in the wood? Any Idea why. Since I rarely have boards wider than 6" I ussually just use the other half of the planner. But what should I do to fix this. I thought about exchanging it at HD but really do not want to lug 85Lbs back upstairs and to the store?
    What kind of "line" is it? Does it occur on the top (planed) side of the wood or on the underside?
    An indented "line" (not very likely)sounds like a burr on the blades. A raised "line"(more likely) is probably a chip in the blades. Usually occurs from hitting something hard (nail, grit, etc.) in a piece of wood. You can get rid of the indent by offsetting just one of the blades just a touch so that the chip is not "in line" on all of the blades. You can also "flip" the blades over if necessary.
