R4511 Question
  • R4511 Question
    The R4511 is my first table saw and I love it. One issue: Removing the riving knife for dados or my crosscut sled is a bit of a hassle. Is there some easy trick I am overlooking? I definitely want it on under normal ircumstances.
    Re: R4511 Question
    After replacing the fence/blade, I love mine also.
    Re the knife, I just tap the little handle behind the blade to loosen it, then pull it straight out and while holding it, lift the knife out.
    GAS
      Re: R4511 Question
      I no this sounds stupid, but I can't locate the handle. What am I looking for?
      Thanks for the help,
      Chip
        Re: R4511 Question
        Chip
          Re: R4511 Question
          The 'handle' is small, gray colored item located on the bottom mechanism that holds the knife in place. It may need a little tap to loosen it, but then you can lift the knife out of the seat in goes into.
          To replace the knife, replace it back in the slot and tighten the 'handle'.
          GAS
            Re: R4511 Question
            Thanks for your replies and patience. I don't think I have that knob. Is it supposed to be where there is an empty threaded area in the picture?
              Re: R4511 Question
              Chipbyrd, from what I can see in your pics, I believe that is where the handle should be. Again, it should be directly behind the blade on the right side of the 'box' that contains the riving knife.
              Good luck,
              Big G
                You have a missing part! The handle on mine is spring loaded and when twisted backs out enough to release the riving knife. Down load the parts list and manual to see what I.m talking about.
