I have a router table with a 9" X 12" insert. I am looking for a router loft that will fit this size insert opening. So far no luck. Can anyone help me.
Router lifts
Re: Router lifts
this may work you provide your own plate
http://www.rockler.com/product.cfm?p...6&site=ROCKLER
there are many plans you build your self, on the net
http://3dwoodworkingplans.com/034-router-lift/
here is one that just uses a jack under the router for a lift,
http://www.finewoodworking.com/works...uter-lift.aspx
http://www.google.com/search?q=route...w=1280&bih=800Last edited by BHD; 07-13-2013, 10:29 PM.Push sticks/blocks Save Fingers
Re: Router lifts
Originally posted by mcoge View PostI have a router table with a 9" X 12" insert. I am looking for a router loft that will fit this size insert opening. So far no luck. Can anyone help me.
http://www.woodpeck.com/liftshome.html
Note to forum administrator: I see that the URL posting problem has not been fixed yet, maybe it's time. Still have to post then come back and edit the posting to add a URL.Last edited by Bob D.; 07-14-2013, 05:47 AM."It's a table saw, do you know where your fingers are?" ? Bob D. 2006
http://cordlessworkshop.net/
Re: Router lifts
I did a simple search in Google for
router lift 9" x 12"
and got this:
http://www.mlcswoodworking.com/shops...powerlift.html
The insert is 9-1/32" x 12-1/16". Either open up the opening in your table or shave the insert down to fit.
Shouldn't be much work either way."It's a table saw, do you know where your fingers are?" ? Bob D. 2006
