Router lifts
  • Router lifts
    I have a router table with a 9" X 12" insert. I am looking for a router loft that will fit this size insert opening. So far no luck. Can anyone help me.
    Re: Router lifts
    this may work you provide your own plate
    http://www.rockler.com/product.cfm?p...6&site=ROCKLER
    there are many plans you build your self, on the net
    http://3dwoodworkingplans.com/034-router-lift/
    here is one that just uses a jack under the router for a lift,
    http://www.finewoodworking.com/works...uter-lift.aspx
    http://www.google.com/search?q=route...w=1280&bih=800
      Re: Router lifts
      Is your opening 9x12, or is that approximate. I ask because that is close to the standard 9-1/4 x 11-3/4 size used by Woodpeckers and many others.
      http://www.woodpeck.com/liftshome.html
      Note to forum administrator: I see that the URL posting problem has not been fixed yet, maybe it's time. Still have to post then come back and edit the posting to add a URL.
        Re: Router lifts
        The opening is 9 x 12. It is the grizzly T10432 router table. All help welcome.
          Re: Router lifts
          The opening is 9 x 12. It is the Grizzly T10432 router table. All help welcome.
            Re: Router lifts
            I did a simple search in Google for
            router lift 9" x 12"
            and got this:
            http://www.mlcswoodworking.com/shops...powerlift.html
            The insert is 9-1/32" x 12-1/16". Either open up the opening in your table or shave the insert down to fit.
            Shouldn't be much work either way.
