Blade Shifting on Ridgid R4512
  • Blade Shifting on Ridgid R4512
    I recently purchased a Ridgid R4512. I put it together and made all the adjustments but I notice that when I installed the riving knife and tighten the handle the blade and the main trunnion shift forward. Same thing happens when I remove the riving knife but it shift backward .It does not change the aligment of the blade but I was just wondering is this normal?
    Re: Blade Shifting on Ridgid R4512
    no, it is not normal. has this shifting been checked with some sort of measuring tool to verify that the blade alignment isn't shifting a few thousandths? hard to see with the naked eye. i'd get a $10 dial gauge at HF, attach it to my miter gauge and determine if the alignment to the miter slot is shifting also.
      Sounds like something could be loose.
