How To Post Images
See more
See less
TS2424 router table to replace cast iron wing
  • #31
    Originally posted by m00n:
    The entire weight of the table will be resting on the rails because the cast iron table has no bolt holes what so ever.
    Cast iron drills real easy. You can drill your own holes in a couple minutes if you want to.
    Lorax
    • #32
      mOOn,
      I have a class to attend tonight but if I get a chance, I will get you some measurements...
      As far as the cast-iron goes... I drilled my own holes through the aluminum router table frame and cast iron... I think I put 4 or maybe 5 holes through it...
      I would be glad to give you some rough hole dimensions if it would help...
      Edit: The "Fliptop Stands" are like $30.00 ea... they are very handy... I have 2 that I use all the time...
      [ 02-03-2004, 05:35 PM: Message edited by: Big Johnson ]
      Regards,<br /><br />Big Johnson<br /><br />Pictures: <a href=\"http://www.woodworkersweb.com/modules.php?set_albumName=albuv85&op=modload&name= gallery&file=index&include=view_album.php\" target=\"_blank\">http://www.woodworkersweb.com/modules.php?set_albumName=albuv85&op=modload&name= gallery&file=index&include=view_album.php</a>
      • #33
        Aaaahhhhh... Those things. I already have 2 of them.
