Where to get Zero clearance insert for
  • Where to get Zero clearance insert for
    TS3560. I need one, Thanks. Actually, I found some. Thanks anyway.
    [ 08-08-2005, 06:48 AM: Message edited by: Golfmore ]
    Did you find them for $12.99?
    web page
    Lorax
      Actually, thats $19.74 after you add the totally outrageous $6.75 they charge for shipping the thing. You mentioned you already found a source so it may be to late but why not just make your own.
      ------- Henry Ford
        If you buy 4 like I did, it's only $14.92 ea. including shipping.
        A lot cheaper than any other place I've found.
        I made a couple of my own, but the "store-bought" ones are nicer. To each his own.
        [ 08-08-2005, 12:47 PM: Message edited by: Lorax ]
        Lorax
          How do I make my own zero clearance insert. Specifically, how do I do the setscrews adjustment stuff?
            I just predrill the four holes using a bit that is slightly smaller than the set screw that I'm going to use and then just screw them in until the ZCI is level with the saws tabletop.
            ------- Henry Ford
