Stopping rust
  • Stopping rust
    Hello, I am setting up a shop in my basement. When I purchased my table saw I asked the salesman about rust protection, and he told me to thourghly clean the milled surfaces and apply a quality car wax to them. This seemed to work well for a few weeks. But now I have rust on the cast iron extention of the t.s. and the table of the d.p. Could I please get some ideas on how to retard this longer or eliminate the problem altogether? Thanks, John
    First things first. DO NOT use car wax on a table saw! Use furniture wax such as Johnsons.
    You can also buy a product known as "Top Coat". This is a spray on that lasts around six months. Wax needs to be applied @weekly depending on how often you are using your saw and the amount of humidity in your shop. I coat my saw tops every two weeks. (Also my saw blades each time they are cleaned).
    Support Our Troops!
    www.mnpatriotguard.org
    www.patriotguard.org
      Well, let me refine the suggestion even further---don't use any car wax---particularly if it lists silicon/silica as an ingrediant---it can spot your wood. Second, liquid or spray on car or furniture wax, are essentially watered-down versions of good old paste wax. I've been using paste wax for years and as long as I give the ts and other cast iron, a coat every couple of months (every month during our rainy season)--I have no rust---
      Dave
      Dave
        I agree with the comments about using paste wax every few weeks or so. I also have a basement shop and run a dehumidifier down there. Not really sure if it helps but figure it can't hurt. I have had no rust problems. Dave
          Try Penetrol made by Flood. It is in the paint department of HD. Once dry apply Johnson paste wax then you can concentrate on woodworking and not rust. I apply wax only about every three months and have not had any problems since starting this procedure.
            Thanks to all for the advice. Now I have a better idea of how to attack the problem. I do plan on a dehumidifier. Thanks again!
