Belt for TS2412
  • Belt for TS2412
    I am thinking about replacing the power belt on my TS2412 table saw. Should I just order one from Ridgid or is there something better. Does it really make that much difference?
    Thanks for any help!
    Bob
    I'm going to make the assumption that the belt that you have on your saw is the same belt that is on my 3612. If that's the case than you need a Bando Rib-Ace #417-J or an equal to it. Your best bet might be to go to a local automotive store. If they don't stock it, they should be able to get one for you. Bando's Website has a directory where you can find out where the closest Bando distributor to you is located.
      Thanks, I figured out that my problem was the pulley on the motor had worked loose. When time comes to repalce my belt I certainly will take your advice.
      Thanks again!
