Box Joints
  • Box Joints
    I was experimenting this weekend with box joints. I made myself a little jig and it works fine, but here's my question:
    Is there any disadvantage to having the box joints smaller than the width of the wood? My arbor will only support a 9/16 dado so I was cutting 1/2 box joints on 3/4 stock.
    Any suggestions?
    Thanks,
    dp
    The only disadvantage I can think of is that you will have more cuts to make. Perhaps if the wood was thicker the joint may start to become visually strange looking (1/2" joint on 1 1/2" material) but that is also just a matter of taste.
      set up jig to allow you to make 1 and 1/2 passes for each joint. with a 1/2" dado blade that will give you a 3/4 joint. its more work but it will give you the joint you want without changing your arbor
      [ 05-17-2005, 11:58 AM: Message edited by: Conkle73 ]
        Thanks, dp
        Just out of curiosity, what kind of saw are you using?
        Lorax
