Square pegs to hide screw holes
  • Square pegs to hide screw holes
    How can I create 1/2 inch square holes for pegging screw holes in an Arts&Crafts style molding.
    You can drill them out with a drill bit to depth, then shear the sides to a square shape using a very sharp chisel the same size as one side of your square tenon...
    also you can get a moritising bit for your drill press if you have one and do it that way...the bits have square cutters on the outside.
    [ 10-05-2002, 12:43 AM: Message edited by: KellyC ]
