Porch Columns
  • Porch Columns
    Repairing my porch. Want to embellish the square columns with moulding from the railings down. Among other things I want to add circular moldings with a 1"-1.5" radius around the square column.
    I could use some suggestions with the circular moldings. Thanks [img]smile.gif[/img]
    Construction details - four 4"x4" CCA posts covered with 1x (8" square at the base tapered to 5" square at the top). I want to maintain the one piece integrity of the CCA; everything else may be compromised.
    Hi Van, I am a tad confused as to what it is your trying to do.
    I think what you mean is to wrap a half round horizontally?? you can purchase half round from your local lumber yard. Hope that helped ya
    <a href=\"http://www.woodshopphotos.com/gallery/Ralphs-workshop\" target=\"_blank\">www.woodshopphotos.com/gallery/Ralphs-workshop</a><br /><br />I can fix anything......where\'s the duct tape ?? :-)
      Thanks for responding Ralph. Yup 1/2 round horizonally. But I have to build it around an exiting square column. I saw it on the cover of the Sept. issue This Old House.
      I agree my first request was a little confusing. I'll try again.
      The existing tapered columns are in place without any moldings. I want to add fanciful moldings from the railing down. Beef it up a little, one of the features will be a half round with a 1”–1.5” radius. So it will appear to be a circular molding around a square column.
      They are cosmetic only. They will not be under or on top of the supporting 4”x4” PT infrastructure. They are not load bearing.
      I’m thinking I have to build it out of 2”x4” stock around the square column (dowelled dry fit) and then routed. After routing, refit and glue.
      Thanks again. [img]smile.gif[/img]
      Someone suggested in another forum that I should buy the rounds from a local yard and cut out the box shape from the the middle, allowing for the kerf of the blade. I thought that was doable and easier than what I suggested above.
      [ 09-22-2003, 10:54 AM: Message edited by: Van ]
