Compound mitre saw accuracy
  • Compound mitre saw accuracy
    When I detent the saw at 45 degrees it does not cut exactly 45 degrees.
    Can this be adjusted
    Cammile,
    Consult your tool's manual. I only have a cheap Ryobi 10-inch CMS that I recently purchased, but even with it there are adjustments. The only thing that I don't see that is adjustable is the "stops", which are basically notches on the leading edge of the table. You can adjust the fence, but if the 90-degree is proper and the notch for the 45-degree is off, I don't know how you would address that. Hmmmm, now I think I'll have to go check that out.
    I hope this helps,
