Is there a T Bolt size that matches the miter slot for TS 3650?
  • Is there a T Bolt size that matches the miter slot for TS 3650?
    Hi guys
    Regards
    MiniMe
    PS: I am new here glad to see we have dedicated forum for these table saws and other power tools of the same brand
    The miter slot on the TS3650 is a standard 3/4" wide. If the ones you're finding are larger than that you could just grind them down to make them fit. Why are you going to use a t-bolt in the miter slot if I may ask?
    The Leading Cause Of Injury In Older Men Is Them Thinking They Are Still Young Men.
      I saw some jigs that need the jig to be tighten in position ...one simple example are the featherboards like below. Some times you need just a stop. The alternative is a mag switch or clamp something but a t-bolt is really cheap in the end. I am thinking about buying this set https://www.princessauto.com/en/deta...it/A-p8445389e but I need to know if the bolts fit the t-stot native to the table saw
      Click image for larger version  Name:	maxresdefault.jpg Views:	0 Size:	114.3 KB ID:	741932
        Similar question here
        https://www.lumberjocks.com/topics/20118
          There is such a thing as a miter slot nut. You can see them on Woodpeckers website but they can be had from other sources too where you can get just the nut that slips into the miter slot. I think Peachtree Woodworking has them and maybe also from Woodcraft or possibly Rockler and no doubt they are on Amazon but that's a guess as I have not researched all these possibilities.
          This is assuming you're talking about the miter slot which is in the table. If what you are asking about is the T-slots in the fence yes there are also t-bolts available for those slots too and they are easier to find.
            It seems that standard t bolts can't be used
            • 5/16" - 18 bolt bottom plates are 9/16"W x 7/8"L x 7/64"H
            • 1/4" - 20 bolt bottom plates are 9/16"W x 11/16"L x 7/64"H
              I tried an elevator bolt then come in various lengths and 1/4-20 thread which fits perfectly the knobs
              It took me 2 minutes to adjust one to fit the miter track 2CAD a piece (2" long)
                Again, are you talking about the miter slot in the table or T-slot in the fence? Most people will call the 3/4" wide slot in the table a miter slot because the miter gage runs in this slot. It is undercut to have a t-slot shape but it's not known as a t-slot. Yes, you can use an elevator bolt modified to fit the slot.
                Is that your YT Video?
                  no that is not my video
                  yes I was referring to the one built into the table saw
                    Here is another source for a miter slot nut.
                    https://www.infinitytools.com/shop-e...cks/t-slot-nut
                    They are sold in packs of 10 for just under $10. One dollar a nut is expensive
                    but 10 of them is probably all you'll ever need and they are better suited to the
                    task than a modified elevator bolt or toilet bolt.
                      The dimensions of the plate opening on the casting and the dimensions of the lift plate are theoretically the same. The first time I installed the JessEm lift, it was quite a snug fit, but it went in. I guess it expanded a little bit after installation, because I took it out of the table for the first time a few weeks ago and it wouldn’t fit back in without being forced, so I took a sanding block to the edge of the lift’s plate to ease the fit – didn’t take much. As for anchoring, the lift plate sits on several grub screws, and I never felt a need to anchor it down beyond gravity and friction. I suppose if you want, you can drill the cast iron and use the countersunk holes at the corners of the plate with a machine screw, nut and fender washer. The casting doesn’t have quite enough metal that I’d consider trying to tap for threads in that spot. Having used this combination for more than a year now, I am still very, very happy.
