WD12800 Replacement Parts
  • WD12800 Replacement Parts
    I have an older vacuum/blower (Model #12800) for which I need a replacement part to attach the hose to the vacuum body itself. The original has a red clip and is nominally described as a 2.5" fitting, but with the rubber ribs on it, actual measurement is closer to 2 5/8. Standard 2.5" adapters are too loose in the opening. Anyone know where I can a replacement fitting?
    did you try RIDGIDParts or eReplacementParts.com or any of the other parts sources?
