R4514T Dado throat Plate
  • R4514T Dado throat Plate
    Has anyone come up with one or made one? I just got the saw, it up and running and would like to get a dado throat plate.
    The part your looking for is # 089240028701 dado insert as listed in operators manual.
    A search of the internet for one yielded nothing , so I would call RIDGID power tools customer care 1-800-474-3443 and ask if they are available or are they still on back order ( they where when the saw was introduced ) .
    Let the Forum know how you made out it helps others in the same boat.
      Make your own zero clearance/dado throat plate, https://www.youtube.com/watch?v=KeSJQQYu478
      The Leading Cause Of Injury In Older Men Is Them Thinking They Are Still Young Men.
        I had a Ridgid TS3650 for many years, and sold it recently. When the guy bought it, I gave him a 1/2 dozen blank insert plates that I made. They are are not hard to make, but it takes a few minutes to make them. Get enough material and batch out like 2 dozen. Then you will not need to make them again for a VERY long time.
        Use a material that is stable. I used laminate flooring off-cuts that were very close to the perfect thickness. I shimmed them up just slightly with a bit of blue tape. Avoid solid wood, as it can warp easily and can change size with seasonal humidity.
        Here is a good video. Make sure that you use HAND PADDLES when flush trimming.
        https://youtu.be/TEHjJbpRzhA
          I called Ridgid parts line today- May 15- and the customer rep said that the part was on back-order for two months! Literally July 15. So it looks like getting this directly won't be an option for a long time.
          Direct link to Ridgid's shop for the Dado Throat Plate.
            Here's another site that has them listed but none available. BUT, the price is right at $2.99 each.
            It might be owrth signing up for a couple of these at that price. For ~$10 plus shipping you could have three of them whenever they show up. But might be worth the wait.
            Just a suggestion. I have never bought anything from this place but I know they've been around a while.
            https://www.ereplacementparts.com/th...MaAhsLEALw_wcB
            http://cordlessworkshop.net/
              Thier now saying back ordered to Nov.
                These can be found on Esty. Go to Etsy.com and search by model number there....
                • Bob D.
                  Bob D. commented
                  Editing a comment
                  This is an old thread, so I doubt the OP is still looking. The last time he visited this site was 4-26-20, the day he inquired about the dado insert.
