bottom ruber wheel & blade problem
  • bottom ruber wheel & blade problem
    I have a BS14002 with riser block, and have been using it without problem for 5 months. I am ripping 6" hard maple with a 105" 5/8" aggressive blade and for some reason the blade stays on the upper wheel but the rubber of the lower wheel is coming forward over the lip of the aluminum with the blade on it, and then sawing into the left hand blade cover.. This has happened twice now, but only with this heavier blade. I am making all guide adjustments as the manual specifies, and have the tention set for 1/2". Anyone know how to fix this?
