TS3650 My Christmas Present
  • TS3650 My Christmas Present
    Hello......
    After my first week with this saw, it has not disappointed. I have owned 2 others in the past, and this one is the quietest and quickest I've ever had.
    Once you get past using both metric and American standard bolts and the problems with the pictures in the assembly, (ie page 32...shows motor mounted).
    Now...accessories...where do I find them...its seems that ridgidparts.com have nothing for the TS3650
    1... A blade that the kerf removes .125 The blade that comes with the saw removes .102
    2... A zero clearance table insert for this model....or do I have to make one.
    Thanks
    "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!"
    ~Benjamin Franklin
    Welcome!
    Any 10" full kerf will do the .125 cut. Good choices are the WW and Freud.
    I have a Ridgid T3 Titanium which I really like. http://www.ttrackusa.com/ has the inserts, or as you said, you can make your own. It only takes a few minutes, but those minutes can be hard-to-find.
    HTH,
    ken
    Poplar Branch Wood Crafts
      Here are a few examples of 10" full kerf combination blades you might want to consider;
      1. Forrest WW-10-40-125, .125 kerf
      2. Freud F410, .126 kerf
      3. Freud LU84R011, .126 kerf
      4. Amana 610504, .135 kerf
      5. Amana PR1040, .134 kerf
      6. CMT 213.040.10, .130 kerf
      7. Systimatic 51821, .125 kerf
        Originally posted by KenM
        Welcome!
        HTH,
        ken
        Thanks!
        I ordered 2.
        OK..now for something different,
        I came across this in my Fathers estate tool collection...The name stanley is on the handle...but what is the name of this jig?
        ~Benjamin Franklin
          Looks like an old tenon jig of sorts, but I can't say for sure as I've ever run across one like that.
          Is the piece with the handle movable up and down?
            As Bob said, it is an old tenoning jig. It should have a runner that rides in a miter slot.
            Looks like it's Delta gray. Have a look at http://www.owwm.com/ under Delta. If you don't see it, post there, there is a good collection of old woodworking tools.
            ken
              yes there is a runner under that large plate to the left...in fact I have it indexed into the table top on the photo.
              The large handle is fixed into one position...there are other holes in the plate, my guess is for other attachments. Funny you should say Delta gray....my fathers saw was a delta, but this says stanley (tools) on the main handle.
              Well anyway, I'm going to use it to cut kerf slots for glass into 3/4 by 3/4 sticks.
              Thanks for the help...Happy new years!
              ~Benjamin Franklin
