Stacked Dado Help
  • Stacked Dado Help
    I have a TS 3650 and am using a 8" freud stacked dado set. If I am making a dado any wider than 3/4 of an inch I can not use the washer under the nut because the arbor is to short. Is this safe?
    SSG, U.S. Army
    Retired
    K.I.S.S., R.T.F.M.
    It is safe, check page 44 of the owners manual ...
    When using the dado or molding
    head, it is not necessary to install the
    outer (loose) blade collar.
      The manual that came with the saw is different than the online one. I totally missed that till now going to print out the online one. Thanks for your help.
      SSG, U.S. Army
      Retired
      K.I.S.S., R.T.F.M.
