wet/dry vac WD1450
  • wet/dry vac WD1450
    Do any of you guys have this one? It looks like a pretty nice unit. What I find most interesting is that it is rated at 6.0 hp but draws 11 amps. The WD1850 is rated at 6.5 hp, but only draws 10 amps.
    I will be using it primarily to catch the dust from my 3650. Will it connect right up to the built in dust port, or will I need an additional adapter?
    Should I be looking at something else?
    Not being particularly good at remembering those model numbers, is that the 12 gal vac? If so, I've got one and I love it. Excellent suction, not too noisey and of a size that is convenient to both moving around and having a fairly adequate capacity.
    I'm not sure what size the port is on the table saw, so I don't know if the standard hose will fit directly. But an adapter is available for only a few buck, I'm sure.
    I hope this helps, it's a great vac,
      I have the equivilant Shop Vac brand. I think it has a 2 1/2 inch hose, which fits in the 3650 dust port just fine.
      I use mine for the saw all the time. I'ts great and with my router table extension it fits under the saw great.
      With sufficient thrust,<br />Pigs fly just fine.<br /><br /><a href=\"http://mysite.verizon.net/res7alut/waynesprojects\" target=\"_blank\">http://mysite.verizon.net/res7alut/waynesprojects</a>
        It's the Pro series 14 gal model. Here's a link: http://www.ridgid.com/Tools/14-Gallon-Pro-Vac/index.htm
        Thanks for your answers guys!
