Flag Display Case plan
  • Flag Display Case plan
    Does anybody have a free flag display case plan or know where I might find one. I see that Rockler has a plan for $9. I searched the net but can't locate a free plan, there's gotta be one out there.
    Or if you have made one yourself, maybe you could share with the forum any tips or tricks, case dimensions for a std 3x5 flag, etc.
    You will find a couple here. You will have to adjust the dimensions to fit your flag.
    www.woodworkersworkshop.com/resources/index.php?cat=109
    For some reason the link doesn't work so you will have to type all that crap yourself. Sorry about that.
    Edit:
    It works after I posted it. Maybe it just doesn't work in preview mode.
    Lorax
      I got mine from the Wood Magazine website. I think it was $6 and used simpler angles that some. Just finished it in time for Christmas.
        Thanks to both of you, that's what I was looking for.
        Now to see if I have enough walnut to make a couple, if not, then it will be some other wood.
          Re: Flag Display Case plan
          Guess I'll drag this old post back to life!!!
          I'm building two flag display cases, one for my Father's and one for my Brother's burial flags. I have all the parts cut out and the two sides glued up on both of them. I'm making the bottoms so they attached with pocket screws and can be removed in the future if need be.
          I was wondering if it's a tradition to leave the inside of the case unfinished, so the flag would be touching a natural surface?
          Did you guys leave the inside of your cases unfinished?
          Thanks!!!
          Michael
            Thanks for digging up this post as I need to make one for the flag I got when my father died.
              Hi there,
              Not too sure if this will help or not, but I came across your post and thought that this website might be helpful to your post. They specialize in display cases of many makes and models. I am sure they can at least point you in the right direction.
              quality crafted display cases
                I cant access the plan for the flag case. Doing something wrong? or is there no plan?
                  http://www.dmwoodworkers.com/PDF_Gen...eInstrWUFA.pdf
                    Stryker223 and Pez:
                    Sorry for your losses. It is nice to know they were honored with flags at internment.
                    To answer the question, finishing the inside is a good practice if you have the time. Use lacquer or shellac for a quick drying inside finish. It will help preserve the case.
                    Nothing requires the flag to rest on a natural surface, but if that has special meaning to them, their loved ones, or you, then feel free to do so. The purpose is to honor them and their memory, so keeping that in mind will guide you as to what is appropriate..
                    Go
                    PS: I realize this is late for the original postings, but added it for future viewers
