Setting up jointer / Planer cutters
  • Setting up jointer / Planer cutters
    Woodcraft sell a magnetic gizmo to hold cutter blades true while you lock them up. However it will set you back 150 - 250 bucks depending on the size of your machine. Here is an idea to help sped the process up without any concern related to how true they will run.
    Depending on the size of your machine these little wonders will hold the house up while you lock them cutters up, depending on how your blades lock you can use it as it is or make a little cradle, one of these will hold a cutter no problem:
    http://www.gaussboys.com/product_inf...products_id=77
