Tp1300
  • Tp1300
    After reading here about feed problems with the planner I decided it was time to clean the rollers and wax the table as it was not feeding as well as it should. Got all needed stuff and got started so far so good. Now how do you turn the rollers to clean them? Turning the belt like the book says to change the blades don't work. Do you just clean the exposed part turn it on and then off to clean them and keep repeating this process until they are clean?
    SSG, U.S. Army
    Retired
    K.I.S.S., R.T.F.M.
    Kiss
    Yes.
    Unplug the machine each time.
    Lorax
