Dust Collector Pan
  • Dust Collector Pan
    Has anybody tried any of those cheap plastics dust collector pans for a TS3650 and if so how well did it work? I plan on closing off the back of the saw and was planing on building my own dust collector pan, but was curious about the plastics ones.
    Dust collecter pan
    I assume you mean the plastic part sold by Ridgid that attaches under the saw and provides a connection for a dust collector/shop vac hose of around 2 1/2"? I have one of those on a ts 2412, a previous model. It works ok, but a larger discharge hole, 4 or 5", and a true dust collector, would move a considerably greater volume of air hopefully resulting in more effective dust collection. If you use the search feature in this forum, there are a few threads dealing with this topic.
      I was actually thinking about one of these from Amazon:
      http://www.amazon.com/gp/product/B00...lance&n=228013
        I made something similiar out of a piece of ply and a toilet flange and it works great. For what Amazon is selling that store bought one for, you're better off to buy it then make one.
        ------- Henry Ford
          BadgerDave
          How did you fasten it to your saw?
            L Turner, I just drilled holes in the ply and bolted it to top of the stand just below where the saw sits. Keep in mind that I have a 3612 but IIRC there were some predrilled holes already there that I utilized.
            ------- Henry Ford
              I misunderstood. Thought you had a ts3650 as I do which has a 2" outlet for dust
                I replaced the Ridgid one with the shown at amazon. It went in easy and works must better with a DC. the original one with the 2.5 in port would clog when using the dado blade.
                  Did you have to modify it to fit the TS3650?
                    For $3.99 you can't beat that price! If its not big enough to cover the bottom of the 3650, then cut a piece of ply and mount it on that.
                      no joy in starting my new 3650
                      So after spending the last 10 hours assembling my new 3650 I finally get to plug it in and try it out so guess what ? the blade wont turn ive rechecked everything and still the motor just humms if I let it go for a while it eventually blows the breaker Somerbody help me Please
                          Man, that really sux! I feel your pain.
                          Does the motor spin freely if you turn it by hand?
                          Did you mess with the wiring?
                          Are you using a 115v outlet?
                          If you can't get it running, take the motor back to HD and make them give you a new one, even if they have to take one out of a new 3650 box. Don't let them tell you that you have to bring the whole saw back.
                          Let us know how you make out. Good Luck.
                          Lorax
                            Does the motor run if you remove the belt? Does the blade spin freely with the belt removed?
                            SSG, U.S. Army
                            Retired
                            K.I.S.S., R.T.F.M.
