3650 Pulley and Motor Adjustment
  • 3650 Pulley and Motor Adjustment
    Got my new 3650 yesterday and had it together in about 2hrs... I have been working on aligning everything today. I am 95% happy with this saw and the only thing missing is to do away with some hard starting and minor vibration. I am under the assumption that the occasional hard start I am experiencing is due to mis-aligned pulley and/or improper belt tension. These are also two points that the instructions were essentially worthless in addressing. About every 4 starts the saw starts smooth and without any vibrations. The other 3 are a pretty hard start on its way up to speed. Once it is up to speed it smoothes out nicely. I notice the same phenomena while turning the saw off...
    Any ideas, hints, etc...?
    Other than that it has been great, no issues. Have made quite a few practice cuts and with a Frued 80 tooth it cuts great...
    I had the exact same experience when I put the saw together a couple of months ago. I tried loosening the motor mount bolts so I could move the motor position from side to side. I tried a couple different positions relative to the arbor and was able to find a spot which allowed for smoother startups. I no longer get the hard start. I had to basically fiddle with it to find the right spot. I wonder if there is a better method to aligning the motor to the arbor.
        " I wonder if there is a better method to aligning the motor to the arbor."
        Doesn't the manual mention using a straight edge to help align the pulleys?
          It sounds as if you have the belt to tight. I have found this way the best way to adjust it. With the blade all the way down push the motor all the way in. Then pull it back until the weight of the motor starts to put tension on the belt.
          SSG, U.S. Army
          Retired
          K.I.S.S., R.T.F.M.
            Reply to Needasaw
            Make sure the bolts that secure the trunnions to the table are tight. I believe there are 6 of them. There have been reports of these bolts not being tight when shipped.
            Lorax
              First thing I will check tonight
                That is essentially how I adjusted it... Basically I had it tight enough to allow the motors weight to push on the belt even at the lowest point of belt tension (which is not at the lowest blade setting as the manual says, it is just above that point). This way the motor is never resting on the stop, but always on the belt. I did go on to try progressivly tighter belt tensions with no luck and reverted to the original tension I had set.
                  My manual said to eyeball it... I am going to borrow a magnetic level from one of our welders and stick it to the outside of the saw and the measure distance from a straigt edge placed against both pulleys...(if someone has better idea on how to do this let me know) I don't think this will have any effect as I did randomly try different pulley locations at small intervals from its starting point. No difference.
                    Unless ya got a laser...
                    Like this. Remove belt, check, rotate each pulley 90, recheck. String or straightedge must touch pulley at all 4 points
                    Lorax
                      Thanks!
                      I will try that tonight...they should include that image in the instructions...
