Newbie.. Go Easy.. Lol.. Angle Cutting Help Please
  • Newbie.. Go Easy.. Lol.. Angle Cutting Help Please
    i bought a ts3650.. and all i can say is wow! very nice...
    but i have a newbie question, if i have a large piece of mdf say 32 w x 28h, and i wanna cut one side at say a 45 degree angle.. how doo i go about doing that?the mitre slide isnt long enough to support that cut.. it pulls out of the table.. and help on this would be great.. like a jig or a sliding mitre long enough? some thing to stablize the wood to get a perfect even cut... please help.. thanks in advance
    You could buy an after market miter guage like this one, http://www.woodpeck.com/incramiter1kse.html To make the cut you described however an outfeed table of some sort should be used.
    One way to do it without using your table saw would be to rough cut it with a circular saw and then finish it off with your router and a flush trim bit or a pattern bit.
    ------- Henry Ford
      Another option might be to build a tapering jig large enough to make a 45 degree cut.
      SSG, U.S. Army
      Retired
      K.I.S.S., R.T.F.M.
        45 degree angle
        Did you mean a 45 degree angle on one edge, or make a 45 degree cut across the MDF sheet?
        I'd say try a circ. saw with teh blade beveled at 45degrees, with a long straightedge clamped to it. Not as accurate as the TS, but it would still do the trick
          45 degree angle
            Re: Newbie.. Go Easy.. Lol.. Angle Cutting Help Please
            Even a jig saw would work.
