Trying To Set Up A Small Woodshop
  • Trying To Set Up A Small Woodshop
    I Am In The Process Of Turning My Two Car Garage Into A Wood Shop. I Have A 12 Compound Sliding Miter And The 10" Table Saw Cast Iron Also A 3 Gallon Air Compressop With 3 Nail Guns. Trying To Save For Lathe And Jointer Along With 13" Plainer And Drill Press What Else Would I Need And And The Best Way To Set Up Want To Make Cabinets And Some Furniture For My Own Use Mostly Ridgid Tools By The Way.
    A bigger garage!
      Router and router table.
        Maybe some spray equipment.......
        I too just set up shop in the garage.....
        I live in Mesa....
        Gofor is right though a bigger garage would be nice!!!!!!!!
          Dust collector and air filtration.
          See thread on toxic wooddust.
          Lorax
            1. Clamps
            2. Circular Saw
            3. Drill/Driver
            4. Jig Saw
            5. Clamps
            6. Random Orbital Sander
            7. Zero Clearance Inserts For Table Saw
            8. Feather Board
            9. Clamps
            10. Ridgid Flip Top Stand
            11. Excellent Quality Paint Brushes
            12. Hearig Protection
            13. Clamps
            14. Eye Protection
            15. Patience
            ------- Henry Ford
              good lighting,fans(for cooling your self) i like a rolling work station as it tends to very help for me.mine is 29"high 36" wide 6' long on 6 casters if space would allow i would also think that some type of rack to hold your most used hand tools like drivers hammers(yes you will need and want about 5-10 hammers) rules and many other things would help as well ,but that is something more that you would want build.
              9/11/01, never forget.
                I think the above posts said it pretty well, but if you live in Peoria I'd go for the "1000 ton" A/C unit first.
                It's already too hot for me!
                  Hey BD
                  Don't forget about clamps!!
                  Lorax
                    thats what i forgot thanks for the reply
                      Originally posted by Gofor
                      A bigger garage!
                      i will make that one of my next projects thank for the response
                        I live in Mesa....
                        i was thinking about that would i be able to use the same air compressor with the spray gun attatchment ot do i need a bigger tank i have the one from home depot that comes with the 3 nail guns thank s for the reply
                          i have the ridgir wet dry vac and was told i could attach that to the individual power tools do you know if that would work until i could get a actual system and thank you for the quick response and advice
                            Originally posted by BadgerDave
                            1. Clamps
                            2. Circular Saw
                            3. Drill/Driver
                            4. Jig Saw
                            5. Clamps
                            8. Feather Board
                            9. Clamps
                            13. Clamps
                            14. Eye Protection
                            15. Patience
                            what are the zero clearance inserts and what are they for can i get them at home depot and the flip top stand is that the miter saw utility vehicle?
                            also wanted to say thank you for your help and answers to some questions thank you
                              when you say driver hammers i am unsure of what you mean and is there certain hammers that would be best i have some levels and angle gauges for lack of a better word for figurung out angles for like crown molding any way thank you for your very much appreciated advice thanks again
