Newb question on my TS2400ls
  • Newb question on my TS2400ls
    Hi this is my first post on this board, but I have been searching this site for some time to see if someone had the same question. I have a TS2400LS table saw and is looking to see what dado works best with it, or if you can tell me what to look for when buying a dado blades.
    Welcom bk. I think that any STACKED dado set that you can sfford will work for you. Some say that the freud is a good set, but I have a set that I bought at Lowes that works just fine. I can't remember the brand, but I only paid $50.
    Again welcome and keep the posts coming.
      There are two types of dado sets.
      Wobble dado-
      A wobble dado head is a single blade set a an angle to make a dado. The wobble is cheap, but dose leave a arc in the bottom of the dado cut. Some portable table saws can not use a wobble dado head.
      Stack Dado-
      A stack dado has two outside blades. To make a wider cut you would put chippers a blade with fewer teeth than an out side blade. A stack dado cost more and leaves a flat bottom cut.
      All dado head set come in different sizes some of the most common sizes are 6",7",8". Now you need to ask yourself how deep of a cut do you plan to make?
      A 6"dado can cut up to a 1.25" deep cut.
      A 8"dado can cut up to a 2.25" deep cut.
      some websites for you are http://iseek.com/Projects/omnicat5/index.php?cat_id=0
      The other one is Cmt.
      You will ned a dado inesrt for the tablesaw. www.ridgidparts.com
      [ 01-05-2005, 03:37 PM: Message edited by: Andy B. ]
      Andy B.
