TS3650 question
  • TS3650 question
    Where is the serial # on the TS3650?
    Thanks in advance...
    I don't know if its located in the same spot on the 3650 but on my 3612 it's located on a black nameplate located on the LH side of the saws cabinet.
      On my TS3650, it is also located on the left side of the cabinet (lower rear corner).
      HTH
        Ditto. Take a flashlight under there with you. Even then mine was hard to read - some numbers poorly stamped.
        Later,
        Chiz
