CLR on cast iron?
  • CLR on cast iron?
    Has anyone used CLR to clean their CI table top?
    never tried it but would not recommend it. It is very corrosive and reacts badly with aluminum too. Also you will need to rinse it off which would likely cause more rust. Although it is likely very tempting at this point but keep that new belt sander away from the saw
    But now that you have a ROS try the green scotchbrite with a bit of WD
