Outfeed table for TS3650
  • Outfeed table for TS3650
    Been looking around for awhile for some ides for installing an out feed table for my Ridgid TS3650. And from my searches, I see where others are doing likewise.
    So with some ideas from here or there, here’s the results of my efforts utilizing a couple of 2x4’s and a couple of pieces of Malimine. I used two 15” wide pieces and hinged them primarily because although there are times I will need the extra length, to conserve limited shop space, one of the 15” segments hangs down out of place.
    Yeah so what’s the slots in the top for. One is to remove the Ridgid OEM splitter and the other is because on angled cuts, the greater the angle and compounded by the height of the blade, the motor raises/pivots upward. For a 45 degree cut at maximum cut, the top of the motor needs this hole.
    Other than what’s shown, the setup is straightforward and works for me. .
    Outfeed table – equal to width of cast iron wings X 15”, Oh yeah, the melamine is white, color affected by the fluorescent lighting.
    Extended to full length - 30”
    2 x 4’s bolted to saw case and the upper edge flush against the underside of the regular table. Cutout on the left 2x4 (viewed from rear) is to allow the motor to pivot upward when making angle cuts. Legs are on locking folding brackets
    Not too familar with posting the pics, but hope they show.
    Very nice job. I'll bet that one gets copied.
      That's nice. Thanks for sharing.
      Poplar Branch Wood Crafts
        Nice work Jerrbit. This outfeed table is a huge benefit for the 3650. Thanks for sharing. Regards, DCG
