Walnut double sided 4x8 3/4 plywood $70 a sheet good?
  • Walnut double sided 4x8 3/4 plywood $70 a sheet good?
    I was just offered what appeared to be really nice black walnut 4x8 3/4 thick sheets of plywood at $70 a board... Is this a good deal?
    I know its double sided and looks good... but not know much else...
    Not a bad price at all for double sided ply. Just make sure you can get some lumber to match it for the framework.
      any idea as to what this usually runs? I was thinking in the 120-140 range per sheet for this size double sided. The guy is also selling tons of hardwood and moldings that I will buy for around 1/2 what HD charges for surfaced oak, etc. This is in BOISE, IDAHO if anyone needs the info.
        3/4" walnut plywood runs just over $100 in Portland.
        What type of core?
          I can get it for $112 CDN. 3/4" veneer core plywood flat sliced walnut A2 grade
