Cutting acrylic and UHMW
  • Cutting acrylic and UHMW
    Any recommendations for TS blades for cutting UHMW and/or acrylic.
    Any and all coments will be appreciated.
    Kurt
    (Cool! I still have 10 fingers!)
    you're supposed to cut ~1/8" above the surface to avoid edge chipping, and if you run it through the ts with the masking still on, I've heard it's a good idea to lube the blade with soap or wax to prevent the masking adhesion from sticking to the blade.
    supposedly, you can use blades designed for aluminum and copper. If you have one of those, maybe try it on a test piece. But here's one from Freud for exactly what you're doing:
    http://www.amazon.com/Freud-LU94M010...6?ie=UTF8&s=hi
    if you get one from Amazon, make sure you use the 10% code
    forrest makes some too, which are highly rated.
