TS3612 Splitter Help
  • TS3612 Splitter Help
    I've had my splitter come loose during two cuts now. Might be that I didn't wrench on it enough during the install. However, while trying to get it installed correctly, I noticed that the vertical part of the splitter is not at 90 degrees to its mounting base. Am unable to run rules along both sides of the blade and clear the splitter.
    My question is: before I stick it in the vise and make like a blacksmith, is there something else that I should consider?
    The TS manual has a good section on adjusting the splitter to be parallel to the blade.
    When I assembled my TS, I was also tempted to put it on the vise and adjusting it that way, then I read on and found the correct way to do it.
