RIDGID - How To Cut Stainless Steel Pipe
  • RIDGID - How To Cut Stainless Steel Pipe
    Re: RIDGID - How To Cut Stainless Steel Pipe
    I like the bearing roller and the needle bearing cutter wheel, those are both changes for the better.
    Cutting SS tube is tough. Not so bad for a few cuts, but if you are running tube all day or building
    a panel filled with SS tube, especially heavy wall like .065" or thicker tube, those bearings will make
    the difference.
